Ana içeriğe geç
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
unable to activate touch id on this iPad after screen replacement
Hello everyone,
I had a broken LCD & touch screen in my iPad 5th generation, i purchased the LCD and the screen (Item code: IF128-018-5) i replaced all parts and all looks great..! then when i started my iPad it showed me this msg: unable to activate touch id on this iPad.
So the touch ID is not working and the home button as well, not just the sensor! Please advice.
Thanks
Bu iyi bir soru mu?
Puan 0
1 Yorum
Hi, I have the same problem. The pre-installed home button does not work and if I connect it when the iPad is on, Siri starts.
the old home button works but not touch id, my iPad showed me this message: impossible to activate the touch ID on this iPad.
Please advice
Thanks
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Actually, if you installed IF128-018-5, then that digitizer came with a Home Button pre-installed. That means the Touch ID will not work. You need to transfer over the original Home Button from your cracked display if you want touchID functions. See this guide.
You have to be careful not to tear the flex cable on the HB otherwise you will lose one or both functions.
Bu yanıt yardımcı oldu mu?
Puan 6
2 Yorum:
I did not see that coming! i threw the cracked screen away before i purchased the spare part. in this case what can i do?
tarafından
There's nothing you can do to regain TouchID other than have it repaired by Apple.
tarafından
Yorum Ekle
unable to use touch screen key pad locked. cannot enter pin
Puan 1
1 Yorum:
I have the same problem on my iPad I have I have the same problem as you on my knife generation tablet and it’s so hard generation tablet I had to I tried doing it but it didn’t work. I tried asking my mom to fix it and my dad to fix it but they can fix it so can you come to my house?
tarafından
Yorum Ekle
You probably accidentally broke the home button flex. If it's broken, Touch ID and home button won't work. You will probably need to replace the home button assembly, unfortunately this means that you lose Touch ID permanently since it's paired with the original home button and motherboard.
Puan 0
4 Yorum:
i have not used my ipad for last six months it is fully charged but key pad will not work i am barred out. is there way to activate my touch screen
tarafından
is there anyway to pair the touchID with the new home button
tarafından
@alexplaysroblox Only Apple has access to the proprietary encryption algorithm used to pair the home button to the motherboard so that Touch ID will work. No one else can do it, and Apple doesn't offer pairing as a service; in fact, it's my understanding that they don't actually do any repairs on iPads. Alisha (@flannelist), am I correct here?
tarafından
@dadibrokeit Just checked right now I could be sure I had current info and this is still largely correct. Select models are now eligible for certain parts being replaced, but only via mail in repair. The included models are all very recent (only ones made in the last couple years) and only front camera and battery are eligible and not even for all models.
So effectively. Yes. that's still correct.
tarafından
Yorum Ekle
What if i delete my finger touch setting can i redo the with a new home button if I deleted and disable touch before i replace my screen the first time also can i just blow away my entire iPad Air 2 and start over with either a new home Britton or my old one
Puan 0
2 Yorum:
No. The home button is programmed with the motherboard, there is nothing you can do.
tarafından
Yeah, I got the same problem on 9 probably touch ID the same problem and it’s not even working. Will you come to my house and get it fixed?
tarafından
Yorum Ekle
Yanıtını ekle
Dabbor sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 30
Son 30 gün: 142
Her zaman: 17,021
