Ana içeriğe geç
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
Red lines with booting
Dear people,
When i was charging my iPad Air 1 this screen came up.
It totaly freezed up and with the powerbutton and homebutton pressed in it finally turned off.
I've been trying to charge the ipad for 1 day on the charger, didnt work.
Then i removed the screen and disconnect the battery, didnt work.
Does anyone have an idea how to fix this?
Thanks!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I haven't seen this screen pattern before so I can't offer up a "solution". Did anything happen to the iPad in the days or week prior to this issue? Perhaps it was dropped, damaged, contacted water or was repaired.
At any rate, this device has to be opened up and tested. Perhaps it's the LCD but I suspect a logic board issue. A repair shop that does micro-soldering repairs should be able to troubleshoot this.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Minho! Thanks for your reply!
Nothing happend to the iPad it was just charging.
Do you know which IC or is it the charging electronics?
tarafından
Like I said, it could be multiple things and I haven't seen this pattern before. It could be a damaged LCD, LCD drive circuit or a flex/connector issue.
tarafından
Yorum Ekle
Yanıtını ekle
Luuk Toonstra sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 525
