Recovering data with broken system
Windows 8.1 won't boot on this device. I have some important files to recover from it. Bootable usb with linux doesn't help. Is there a way to get them back?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You can try using an external USB adapter for the drive and then connect it to a working computer to try to copy your data.
Bu yanıt yardımcı oldu mu?
does it have hdd though?
HDD or SSD? both should work fine with a hard drive docking station. You can find them on amazon I'm sure, or just open up your desktop and connect with sata.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 429
6 Yorum
Do you have a working desktop PC? So you could test the disk.
ULEES tarafından
i have but im not sure if it has internal hdd
Tomasz Kowalski tarafından
How did it break? did you drop it? spill something on it?
Aiden tarafından
i installed updates and the system crashed
Problem fixed: i booted the windows 8.1 usb drive, then launched cmd. Using it I managed to move all the files to the usb. However switching between the drives doesn't work without "cd /d c:\".
1 tane daha yorum göster
