Ana içeriğe geç
The Acer Aspire Switch 10 SW5-011-18R3 is a 2-in-1 Tablet with docking keyboard running Windows OS. It was originally released May 2014.
Recovering data with broken system
Windows 8.1 won't boot on this device. I have some important files to recover from it. Bootable usb with linux doesn't help. Is there a way to get them back?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
6 Yorum
Do you have a working desktop PC? So you could test the disk.
tarafından
i have but im not sure if it has internal hdd
tarafından
How did it break? did you drop it? spill something on it?
tarafından
i installed updates and the system crashed
tarafından
Problem fixed: i booted the windows 8.1 usb drive, then launched cmd. Using it I managed to move all the files to the usb. However switching between the drives doesn't work without "cd /d c:\".
tarafından
1 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You can try using an external USB adapter for the drive and then connect it to a working computer to try to copy your data.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
does it have hdd though?
tarafından
HDD or SSD? both should work fine with a hard drive docking station. You can find them on amazon I'm sure, or just open up your desktop and connect with sata.
tarafından
Yorum Ekle
Yanıtını ekle
Tomasz Kowalski sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 429
