How do you get to the screws to remove the handle
How do you disassemble the back of the door to get to the screws?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi @rtcoral ,
Here is a link to the spare parts guide for your microwave door.
It shows an exploded view of the door parts. Part #207 is the handle.
Here is a video which shows how to remove the cover choke (#206) to gain access to the screws that hold the handle.
If you need a new handle, the spare parts link above was not meant as a recommendation to use the supplier. It was only shown to give a view of the parts and their cost, (I can't believe the cost of the handle replacement part!). There are other suppliers online who may suit you better. Just search for JVM3160DF1WW parts.
Hopefully this is of some help
Bu yanıt yardımcı oldu mu?
Hi @ramimoto ,
Here’s a link to the door parts for your model.
If you mean part #206 is blocking access to the screws, use the video in the Chosen Solution above to see how to remove this part so that access to the screws is possible.
No I removed part 206. There is a grid still blocking the screws to the handle. How do I remove this grid.
I have this same issue with JVM3160DF4BB. How do you remove the grid to get to the screws for the handle?
Same issue. There's a metal grid that holds the plastic cover and is seemingly the structure holding the door glass and frame together. The screws for the handle appear to be BEHIND that
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 28
Her zaman: 7,253
3 Yorum
Hi @rtcoral,
What is the model number of the microwave oven?
jayeff tarafından
Hi jayeff,
Model No. JVM3160DF1WW
T. W. Mills tarafından
Model JVM3160DF2BB has a metal grid piece blocking the handle screws. How do I get to the screws?
Rick amimoto tarafından
