Ana içeriğe geç
Sony M-430 Microcassette-Corder can record and play back audio. The one-touch recording and two-speed record/playback and automatic shut-off makes this ideal for on the go recording. Model number M430.
10 Soru Tümünü görüntüle
Can I fix the speakers in my Sony m 430 microcassette corder?
I barely found this sony m-430 microcassette-corder and it works for the most part except the sound quality. When I play back anything I’ve recorded it’s mostly just faded voices with an overpowering static sound. Anyone know what I can do? Or is it time to give up? Thank you!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Try cleaning the pickup head and see if this improves the audio quality.
Use a Q-Tip moistened with IPA 90%+ (Isopropyl Alcohol - available at most pharmacies).
It may also be a microphone problem but you would need to do testing of the circuit to try and find out where the noise was emanating from to prove this was the case.
Here is a link to the ifixit Sony M-430 Microcassette-Corder Microphone Replacement guide. As the microphone is a sealed unit it most probably cannot be repaired and would have to be replaced if it was the cause of the problem.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
thank you so much for the help!
tarafından
Yorum Ekle
Yanıtını ekle
Melissa Castro sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 273
