Ana içeriğe geç
Apple'ın 2. nesil iPad Air modelinin sadece Wi-Fi destekli sürümü. Model A1566.
iPad will not activate after reset
I bought a used iPad Air 2 it was restored, removed from an iCloud account - it was in fine condition and had no physical marks.
iOS 11.2.2
Latest iTunes 12.7.58
However, when I try to setup it up. It will not activate - it says that the Apple Activation Server can't be reached I tried everything ifixit.com is probably my last resort. PLEASE HELP
In iTunes it says, and this is the weird thing, (I can't remember exactly how iTunes puts is but it's something like: "The Activation Status of the device cannot be retrieved because there's a SIM-card inside and it's protected by a PIN)
This is a Wi-fi only model, people.
I tried:
1. Activating it through different Wifi networks on both channels and through iPhone tethering
2. Activating it via iTunes on two different Macs running Yosemite and one Windows 10 PC
3. Activating it through Apple Configurator 2
Please help!
Bu iyi bir soru mu?
Puan 5
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
What you bought may not be what you expect...
I am speculating here but you may have an GSM/LTE version of the logic board inside a regular housing. There is a hardware "fix" that allows you to circumvent iCloud locked LTE boards. It allows them to function as a WiFi-only model though.
Where exactly did you get this iPad? Do you have any recourse or ability to find out more about it's history?
Bu yanıt yardımcı oldu mu?
Puan 3
7 Yorum:
Hi Minho! Thanks for your reply. I bought in on Craig’s List and it was restored when I got it. However, there’s wasn’t an internet connection where we were at the time (we could have used tethering though) during the transaction and everything seemed find and it was in mint condition and no physical marks on it indicating the device had been tampered with. And I saw when the previous owner removed it from iCloud.
Tell me more about the “hardware” fix.
tarafından
http://gsxcloud.com/hardware/icloud-bypa...
I doubt this "fix" works with current versions of iOS. That may be the problem here when you restored it to the latest release, the unlock fix was disabled by Apple.
tarafından
Same problem here, Activation Error occurred after restore.
tarafından
Did you have it fixed?.I have the same issue except the fact that the logic board is for the wifi only iPad Air but the housing is for the cellular version.
tarafından
I have the same issue I tried putting the iPad on DFU mode it still shows the same error message and when connected to iTunes it says disconnect your iPad make sure the sim card is inserted and if you have a sim pin.tap unlock to enter it and then reconnect your iPad
tarafından
2 tane daha yorum göster
Yorum Ekle
DO you think the activating it using a lightning-ethernet adaptor will work to activate it? The iPad is still able to find wifi-networks.
Puan 1
1 Yorum:
i am also get this problem with Alexander, i do many ways to active but failing. i really be hate the ipad no sim, too hard to fix this
tarafından
Yorum Ekle
Yanıtını ekle
Alexander Pontikis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 48
Her zaman: 13,435
