Ana içeriğe geç
Released in Japan on December 12, 2004, in North America on March 24, 2005, and in Europe on 1 September, 2005.
87 Soru Tümünü görüntüle
PSP 1000 will not charge or power on with charger
Hi folks
i done a quick google search & couldn't find any real info on this.
i have a psp 1000 & it will not charge the battery or power on with the charger plugged in. it works with a charged battery & the charger works fine on my second psp 1000.
i have installed the USB MOD to see if it will charge by USB but unfortunately nothing :(
i have also changed the yellow power port on the bottom & still nothing.
seeing as the psp has been out for 13 years now i was hoping someone may have a fix for this.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@therealoctavus Hi!
Just a quick question: does it charge if you install a known-good battery? Does the other (known-good) PSP work with the battery from the PSP you're having problems with? If so, consider replacing the battery.
Bu yanıt yardımcı oldu mu?
Puan 1
4 Comments:
when i have the charger connected without the battery the psp dose not power on so its not the battery its something to do with the psp itself. the psp came without a battery & i have tried two different batteries
tarafından
@therealoctavus Have you checked the fuse? Have a look at this post, maybe it helps How to repair my psp when can't on power
tarafından
thanks for the reply & link Alex, ill give it a look & see if this sorts my problem. :)
tarafından
Did the fuse fix the issue?
tarafından
Yorum Ekle
Yanıtını ekle
TheRealOctavus sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 27
Son 30 gün: 93
Her zaman: 5,859
