Why is there a buzzing sound?
Speaker buzzes at lower frequency.
Bu iyi bir soru mu?
If your JBL speaker produces distorted sound, see the JBL Charge 3 Sounds Distorted problem page for possible problems and solutions.
This most likely means one of the speakers has blown and would need to be replaced. They’re fairly easy to disassemble but unfortunately, I haven’t but been able to find a replacement speaker for the system. You might want to contact JBL in case they can service it.
Bu yanıt yardımcı oldu mu?
I asked JBL about this and received the following reply:
"Authorized repair services nor parts are not available for this product due to the complexity of the product and associated cost of internal parts and technical fees. As we do not service this item, if within warranty terms we would do a replacement. A copy of the original dated bill of sale must be presented whenever warranty service is required. Please refer to your Limited Warranty Card provided in your box for further warranty details."
This is such a shame and wasteful
It is a terrible Customer Service answer. I am guessing that JBL has these made offshore and has no idea of the product structure and BOM. So they don't have the knowledge to tell us were to find parts for the various units. Cheers, TQ
I found what it cause buzzing noise to my brand new charge 4
It was small hole that should be covered from rubber pad,but it was poorly made.
So:
1.Turn of your speaker
2.Push the both radiators at the same time and check if air is leaking
3.If there is sound from leaking air ,you must open the speaker and locate it(charge 4 have tiny circle left from the driver speaker) i covered it with electric tape and now is perfect!
It was very simple solution for me and i hope it work for you guys!
use double tape/something thin tape that elastic on the ripped part.. it works
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 56
Her zaman: 8,808
