Ana içeriğe geç
Small media streaming device that plugs directly into your TV's HDMI port. Originally released by Amazon in November 2014. The latest version comes with a voice-activated remote.
20 Soru Tümünü görüntüle
Amazon Fire Stick not powering up
What to do with an Amazon Fire Stick that will not power up?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 6
Yorum Ekle
4 Cevap
Filtre ölçütü:
I have a Amazon Kindle Fire, but what do you mean by 'Stick'?
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
The amazon fire stick is something that plugs into your TV allowing you to watch amazon prime video on it.
This is the fire TV stick: https://www.amazon.com/dp/B00ZV9RDKK?tag...
tarafından
Yorum Ekle
Make sure that you are using the power supply provided with your Fire TV Stick device. You can connect the included power adapter into the power port on the back of your Fire TV, then plug the other end into a power outlet.
Puan 0
Yorum Ekle
Before I factory started my firestick it was not finding my Network or any around me. So I factory started it, and now I can't get past the setup because it's still can't find any Networks. Can somebody help me with this????
Puan 0
Yorum Ekle
Hello! I hope you got it fixed. If not, and for others having similar issues, try this step-by-step troubleshooting guide on Firestick black screen issues. If it seems like your Firestick isn't powering on AT ALL, then you can also try this Firestick won't turn on troubleshooting guide.
In those articles are troubleshooting steps like these:
10 Most Common Reasons Why Firestick Won’t Turn On
  1. Loose connections
  2. Faulty charging port
  3. Outdated software
  4. Internet connectivity issues
  5. Insufficient power supply
  6. Compatibility issues
  7. Power failure
  8. Broken USB connection
  9. Glitch on your smart TV or Firestick device
  10. Corrupted memory/cache
Good luck!
Puan 0
Yorum Ekle
Yanıtını ekle
Jason White sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 33
Her zaman: 21,142
