Ana içeriğe geç
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
iMac won’t boot with built-in display connected
It had a damaged 30-pin display connector (torn off by previous owner) on the logic board & also some minor damage to the 30 pin ribbon cable.
I bought a replacement connector and ribbon cable from eBay, just to be sure it would connect properly.
Numbers listed on eBay for the ribbon cable:
Part Number: 593-1006 922-9132
MPN: Y593-1006 922-9132
I reassembled the machine, but it would not boot at all. No startup sound, no beeps, nothing. However it does boot with the display disconnected.
I have ordered an adapter, Mini DisplayPort (Thunderbolt) to VGA/HDMI/DVI, to see if will run with an external display, as a workaround.
But I would much rather fix it properly, so it runs with the built in display. Can anyone shed some light on this?
Update (02/07/2018)
@danj,
  • Only 1 LED's is on with all 4 monitor cables which I think is LED #1 as it is a little hard to see through the vent.
  • All 4 LED's are on with LVDS cable disconnected.
  • All 4 LED's are on with LVDS disconnected & backlight power cable connected.
  • All 4 LED's are on with LVDS disconnected, backlight power cable connected & the vertical sync ribbon cable connected. I am also getting a very dull grey illuminated screen/monitor & 3 minutes 10 seconds later screen/monitor goes dark i.e. from the dull grey.
Update (02/10/2018)
Schematic mentioned below:
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
3 Yorum
Hold on here!! You need a mini-display port cable, NOT a Thunderbolt cable! While they look alike they are not the same!
tarafından
What does the built-in diagnostic LED's telling you?
tarafından
@ifixanythink "damaged 30-pin display connector (torn off by previous owner) on the logic board " post some pictures showing the damage on the board as well as the complete board. That way we can see what you see Adding images to an existing question
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@ifixanythink - Barry,
Thats pointing to a short somewhere. Did you get the external display adapter (mDP to VGA/HDMI/DVI) you ordered? I think you'll need to wait until you get it so you can see if the external display works. If it does with the internal disconnected we know the issue is localized within the internal display logic.
Bu yanıt yardımcı oldu mu?
Puan 1
7 Yorum:
@danj Thunderbolt v1 and v2 use MiniDP, v3 uses USB-C. See http://wikipedia.org/wiki/Thunderbolt_(i...
tarafından
@gradientzebra - Here's a bit more clarity on the differences: Thunderbolt and Mini DisplayPort : differences and compatibility
The issue here is using the correct cable. This is an older iMac 2010 which is uses DisplayPort to support external monitors. You can't use Thunderbolt cables on it (I know I've tried). The issue is which came first in this case the iMac is older than the thunderbolt standard so it sets what is needed here.
tarafından
@danj no worries eBay listing said it was mini displayport
tarafından
@danj A bit confusing. I was under the impression that Thunderbolt was the signal, and MiniDP was the physical cable. I still don't quite get it, but that's okay.
Also, I'm sure I posted the above message as a comment, did a mod move it or something? I didn't mean for it to be posted as an answer to this question.
tarafından
@gradientzebra - Even I'm confused at times ;-} !!
Basically, they are using the same connector. But, unlike mDP, TB has a front end driver circuit within the cable! This is what messes you up using it older systems. Think Passive - mDP Vs Active TB cable. The target device then sets which cable, As an example a mDP display only needs a mDP cable for either mDP or TB based system. And a TB device can only be connected to a TB system using of course a TB cable. I find that helps most of the time.
I moved it down so I could respond.
tarafından
2 tane daha yorum göster
Yorum Ekle
hi, i tried to remove the broken connector from my 2010 iMac 27" and while removing the excessive solder using the solder wick, i realized that pin 23 to 26 are connected and pin 27 to 30 are connected.
can you let me know if they are actually connected in the circuits?
based on your schematic above, 23 & 30 are NC, the rest 24 to 29 are LED returns 1 to 6. Does this mean they can be connected together?
Puan 0
1 Yorum:
The schematic is for a laptop LVDS connection not a iMac.
tarafından
Yorum Ekle
Yanıtını ekle
Barry sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 18
Her zaman: 1,528
