How do I enter BIOS
It doesn't say press ___ to enter bios under the toshiba logo. It currently does not have a had drive and I need to install windows. I have tried EVERY key or key combo I can find online. Thanks!
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
From within windows 10:
HOLD the shift key
Point to start, power, restart (make sure you are holding shift while doing this)
You will see please wait (you can release shift after you see please wait)
When it restarts - go to troubleshoot, advanced options, UEFI Firmware Settings, then click restart.
The computer will enter the BIOS settings after restarting.
Good luck!
Bu yanıt yardımcı oldu mu?
Thank you, very helpful.
Thank you .I tried many suggestions ,this was the first one that worked . It is quite involved but it worked on the first try .
You win the internet . I have been looking for the correct way to do this for days and you made my search finally come to an end. THANK YOU VERY MUCH,
KIRKTHEBAKER
Yep! Your method worked perfectly, and nothing else worked at all!
Thank you very much!
Once you turn on the computer, you need to rapidly press the f2 key on your keyboard. Even if you do not see the logo. Keep pressing even after the logo DOES appear. You computer should load right into the BIOS no problem!
I have already tried this. Just boots to the "Insert Book Device" thingy.
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 13,212
