Ana içeriğe geç
Dell Vostro, Dell tarafından iş kullanımı için üretilen bir dizüstü bilgisayar serisidir. Vostro 1500, 2007 yılında piyasaya sürülmüştür.
Why is laptop not working?
Laptop led blinks red on power supply.No beep sound.Battery not working.
Bu iyi bir soru mu?
Puan 2
9 Yorum
Hi @somgud ,
What happens when you remove the battery and try to start the laptop on the charger only?
tarafından
Hi @jayeff ,
It simlpy doesnot work. No sound, no blink on screen ,nothing, only I can see is a dead laptop.
tarafından
Hi @somgud ,
Can you check that the charger is supplying 19.5V DC?
If it is then perhaps the motherboard is faulty
tarafından
I hear you @jayeff if it’s not working on the power supply only then there’s something wrong with the motherboard.
tarafından
Hi @paperboypaddy ,
Hear Padraic not here!
tarafından
4 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @somgud ,
Sorry, without a schematic of the motherboard (systemboard) circuitry it is very difficult to be specific about where the problem might be.
Getting the power light to blink red indicates that at least power is getting somewhere into the laptop. Whether all the separate power rails for the various different voltage supplies required within the laptop itself are OK is a different matter.
Given the age of the laptop (is it nearly 10 years old?), it is easier to replace the motherboard.
Here is a link to the service manual. Click on the systemboard assembly link in the Contents page to view the necessary pre-requisite steps and then the procedure to remove the systemboard.
Hopefully this is of some help
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
What happens when you press or hold down the power button? Give us some more info of the problem please.
Puan 0
3 Yorum:
Red led blinks when I press power button.
tarafından
@somgud what is the red light for? Does it have a icon or is it the power button blinking?
tarafından
Hi @paperboypaddy ,
It is the battery indicator in the laptop.
tarafından
Yorum Ekle
Yanıtını ekle
Somgud sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 639
