How do I replace the thermal paste on the gpu.
I took my gpu out of my pc but I don't know how to safely get to the compound.
Update (02/12/2018)
this is the gpu I need to repaste
Update (02/12/2018)
gpu
Bu iyi bir soru mu?
gpu
Bu iyi bir soru mu?
This may be what you're looking for: Termal Macun Nasıl Uygulanır
Unscrew these screws:
And it should come off. Be sure to clean and reapply thermal paste to mating surfaces when done.
Bu yanıt yardımcı oldu mu?
Not quite what im looking for ,thank you. Is there a way for me too send you a picture of my gpu. It has a x like clamp on it that I assume the paste is under but I don't know how to safely remove it. It kinda looks like the clamp on a Xbox one gpu.
Flat head screwdriver if it's like the Xbox. Then u can get thermal paste cleaner and thermal paste online. A plastic razor blade (similar to the red kind used on lcd displays) should easily remove the paste.
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 857
1 Yorum
@samadam It appears all you need to do is unscrew the screws around the heatsink that attach to the clamp on the other side. It looks like a philips.
I've updated my answer.
George A. tarafından
