Ana içeriğe geç
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Soru Tümünü görüntüle
Soru Kapandı
Brightness Shutdown Problem (Even After Inverter Replacement)
hello guys,
i have a white Macbook Core 2 Duo, model A1181 (Santa Rosa i think), with a brightness problem. it all started when it would shutdown the brightness randomly when it was active or idle. after doing some tests and research, i've noticed that, after the brightness shutdown, decreasing the brightness (via keyboard) to it's minimum and then increase it (via keyboard) would turn the brightness on again. i've also noticed that if i put the brightness to it's maximum that would shutdown the brightness after a few seconds, if it stays one level before the maximum (or lower) it stays on until i do something like touch or move the screen lid (up and down). if i have the power adapter connected it's more difficult to make it shutdown the brightness...only with hard screen lid/notebook movement. connected to an external monitor , the problem only happens to notebook's screen as expected.
i've read many pages and forums and it seems the common procedure for this problem is to replace the inverter. so i've replaced it but the problem didn't go away. so i might try to switch the inverter cable now, but maybe you have a better suggestion.
thank you,
joão
Bu iyi bir soru mu?
Puan 0
3 Yorum
hello mayer,
changed inverter cable....checked connections...both on the inverter and on the board...cable did the normal 'click' when connected on the board...and the problem remains exactly the same....don't know what i can do more...symptoms are the same...maybe i'll take it to some repair shop... :(
thank you so much,
joão
tarafından
something strange is going on here.
after i replaced the cable, i noticed the symptoms were the same. then, i've restarted the macbook and reseted the PRAM and then everything was ok, even in full brightness. to test it more, i did some stress tests and after some 'wide open case to half open case' strong movements it went out again and it became extra sensitive to top case movement then i noticed if i pressed the right side of the screen case (just after the 'macbook' inscription) it would turn off the brightness...only there, not on the bottom case, not on the top of the screen case, not on the left side, only on the bottom right side and even soft touches, then i pressed hard there and increased the brightness from it's minimum and the brightness was ok again, with soft movements, full brightness ok and again, only after strong case movements it went out again...and returned to the same initial symptoms and the bottom right side of the top case doesn't trigger the problem anymore...only case movements :(
tarafından
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
If it does this when the screen is moved, I think you are correct, it sounds like the inverter cable. I'd check its connections and for wear: MacBook Core 2 Duo LCD & Inverter A1181 (fast method) Replacement
Here's the part for the Santa Rosa MacBook Santa Rosa/Penryn Inverter Cable
Please give the last three letters of your serial number before ordering for your exact machine. Also look over this guide: MacBook Core 2 Duo Inverter Cable Replacement
MacBook Santa Rosa/Penryn Inverter Cable Görseli
Ürün
$14.99
MacBook Core 2 Duo Installing LCD & Inverter (fast method) A1181 Görseli
Kılavuz
Zorluk:
Orta
1 hour
MacBook Core 2 Duo Inverter Cable Görseli
Kılavuz
Zorluk:
Zor
1 - 3 hours
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Hook it up to an external monitor and see if the problem persists.
tarafından
The next thing is to replace the inverter, if that fails, you're looking at the LCD. I know of no way to test the inverter besides replacing it.
tarafından
Yorum Ekle
hello mayer,
thank you so much,
joão
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 2,122
