Ana içeriğe geç
The Nikon Coolpix S3100 was released February 2011and has a 14.0 megapixels with a wide 5x zoom and 2.7 LCD screen.
8 Soru Tümünü görüntüle
Why is my camera showing "battery exhausted" after charging
i have replaced the battery ,and after charging the max charge indicated 50% only
and after ipicture taken "battery exhausted" shows.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
4 Yorum:
Are you charging through a computer or with the AC charger?
tarafından
a.c. charger
tarafından
why is my camra showing Battery exhausted
tarafından
The problem with my cool pix aw130 was the little yellow plastic tab that supposed to keep the battery shoved tightly against the terminals . In time , it wears and the battery no longer makes contact ; hence never getting recharged . The fix is simple ! Cut a 1/4” x 1/4” piece of paper , cardboard , or plastic , and wedge it between the yellow tab and the battery . Then recharge , as before .
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Read this on www.tomsguide.com So make of it what you will.
''try this ... i had the same problem with the same camera and this fixed it.
remove the battery, and remove the memory card ... then re-install the battery & turn on the camera. this process seems to reset the camera, if the battery ran too low.
now you can re-install the memory card & battery and resume normal operation.
be sure to check for the small flashing green light on the back of the camera (next to the "flash" indicator symbol). it should be blinking when the camera is charging.''
Actual Nikon fix
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
I tried the procedure unfortunately it didn't work, thanks though.
tarafından
i done as u said and it did not work
tarafından
Did not work. Tried times. Disappointing after buying a new battery and they are not cheap.
tarafından
Yorum Ekle
Those batteries are smart with a chip in them. Only allow so many cycles or limit the time used-years.
One of the best cameras for I have for posting on CL with its PC mode low resolution setting
Puan 0
Yorum Ekle
It did not work. Tried it 3 times. Dissapointing especially after buying new battery.
Puan 0
Yorum Ekle
Take the battery out, make sure it's not plugged in and press the on button about 20-30 times. It worked for me. Good luck.
Puan 0
Yorum Ekle
Yanıtını ekle
colin playdon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 19
Son 30 gün: 112
Her zaman: 12,674
