Ana içeriğe geç
The Toshiba 40PB200 is a 40-inch flatscreen television in the PB200 series. It was released in 2012.
36 Soru Tümünü görüntüle
TV LCD Toshiba 46wx800
good day
I have a toshiba 46wx800u TV, which was cracked in several parts the glass cover of the screen. The TV works well. I want to know if you can take off and change the crystal. and how it should be done.
Thank you very much
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@antoniolg going by your description alone, it sounds like a bad LCD. The only way to fix that is by replacing the complete panel. Here comes the bad news, panels that size are rarely available and will most likely cost more than a new tv (if available). You can pof course try a search based on the label that is affixed to the panel itself and see what you come up with. Another possibility would be to try to find the same make and model TV as yours ut that is broken differently. Then harvest the panel from that. Of course this is based on your description. To verify this, post some images of what your screen displays with your question so we can see what you see. Use this guide Adding images to an existing question for that
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
antonio lopez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 109
