Ana içeriğe geç
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Soru Tümünü görüntüle
iPhone SE mic and other issues
I have an iphone SE that I am having issues with that I hope someone can help me with. It was brought to me to try and fix. First of all, the ear speaker will not work at all, it will not switch over to headphone mode when you plug in headphones. Siri will not pick up your voice, when you open voice memos, the record and play buttons are grayed out and you cannot select them. Also, during a phone call you can't switch it over to speakerphone because the buttons are grayed out too. However, the speaker does work to play music or videos and system sounds. I've replaced both the front camera flex cable and the charge port flex cable with the same results. Do you suppose that There are motherboard issues or is it another part of the phone that I'm overlooking?
Thanks for the assistance.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
No dought that is the fault of audio ic
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
So, is this an expensive fix? I know it involves microsoldering which I can't do. :)
tarafından
Yorum Ekle
Yanıtını ekle
Ethan Grier sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 129
