Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
Back camera gone after water damage
Got an iPhone 6s with some water damage. Managed to get back everything to working order except for back camera. Since it was missing PP2V85 I removed U3200 which had suffered a short with VccMain.
Unfortunately CAM_EXT_LDO_EN seems to be missing too, although the pin is shiny and undamaged.
Does CAM_EXT_LDO_EN show up only when camera cable is connected or should I just say goodbye to the main camera ?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hey Arbaman, what do you mean exactly when you say "CAM_EXT_LDO_EN seems to be missing too"? Do you mean the signal or something physical?
I don't remember probing that before but looking at the schematic, it is connected to a UART RTS (Request To Send) pin on the CPU (maybe they ran out of GPIO's!?). Normally, an RTS will go high to initiate a conversation so that's probably what they do here as well; RTS goes high and enables U3200. If you not seeing a signal, you could always pull it high via PP1V8 (or use a DCPS) to see if that enables the camera.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
@refectio Hey Minho, sorry for my lack of precision but I'm pretty new to iPhone repair attempts..would need some training..lol
Anyway you read my mind, I referred to the missing CAM_EXT_LDO_EN signal which should be enabling U3200 and create the needed 2,85v missing right now.
I will try to run a 1,8v bridge and see if that does the trick..thanks for help for now
tarafından
Yorum Ekle
Yanıtını ekle
arbaman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 29
Her zaman: 469
