My phone does not charge
My phone does not charge or turn on, I connect the charger but it does not start the charge, I put the battery in another phone and it works fine. help please that can be. Thank you
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi!
I think you should replace the charging port. Maybe the IC has gone bad or something. Follow this guide until step16 to see how.
Bu yanıt yardımcı oldu mu?
I was looking for the same thing, can this part be?
https://www.aliexpress.com/item/T-Parts-...
or it is about another
Yeah that's it!
Excellent, I will make the purchase, but most likely it takes 2 months at least to get to Peru, so after that time we will know the result. Thanks for your help.
Check you power connector maybe its loose or Some dirt inside..
the phone does not have more than 4 months of use and I have it saved several months ago because it is broken and now I want to repair it. But I doubt it's dirt. Which part do you think is causing this failure?
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 2,434
