Won’t agaitate or spin
The dial will move through the cycles, but it won’t agaitate, and will fill with water and spin only if I remove the dial and pull hard with pliers. I’m not sure of the part I need.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
If your Kenmore 110 Series Washing Machine refuses to spin or agitate during the wash cycle, see the Kenmore 110 Series Washing Machine Doesn’t Spin or Agitate problem page for possible causes and solutions.
See this video starting at about minute 3:00. https://www.repairclinic.com/Video/Video...
Make sure all your connectors are fully in place, especially the switch you are having a problem with. If the wiring appears to but secure and it still doesn't work, replace the switch. To find that part, we need to know your exact model number and which switch you are having issues with.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 295
1 Yorum
parough pull hard with pliers on what? Which dial? What is your washers exact model number? When you pull on whatever part you pull on, your washer functions correctly?
oldturkey03 tarafından
