Does your Kenmore 110 Series Washing Machine no longer spin or agitate laundry during wash cycles? Does your washing machine also make strange noises or click when you turn on the machine? Kenmore 110 Series Washing Machines are susceptible to a range of problems that could cause them to stop spinning or agitating. Check the following causes to identify and solve the problem.
Broken Drive Belt
If the washer will not agitate, its drive belt may have worn out. Over time, the drive belt wears out due to normal use. The belt should be replaced every two to three years, depending on how much the washing machine is used. Use the Kenmore 110 Series Washing Machine Drive Belt Replacement Guide to replace the machine’s drive belt.
Faulty Lid Switch
If you have replaced the washing machine’s lid switch and the machine is still not agitating laundry, it may have a faulty lid switch. The lid switch assembly can fail either mechanically or electronically, making this a very common problem. Use an Ohmmeter to test any electrical switches near the lid switch for continuity. According to their design, the lid switch should have continuity. If your Ohmmeter does not show that the lid switch has continuity, use the Kenmore 110 Series Washing Machine Lid Switch Replacement Guide to replace the washing machine’s lid switch.
Faulty Water Level Sensor
If the washing machine is not able to detect that the water level has reached the desired height, it will not agitate. Open the washing machine’s control panel and look for the water level valve. If the plastic tube attached to the valve appears clogged, use vinegar to unclog it. If the switch appears corroded, it may need to be replaced. Use the Kenmore 110 Series Washing Machine Water Level Sensor Replacement Guide to replace a faulty or corroded water level sensor.
Faulty Motor Control Board
If the washing machine still does not agitate or spin, the motor control board may be defective. The motor control board is designed to provide power to the washing machine’s motor. If the motor control board is defective, the washing machine may not function at all. Use the Kenmore 110 Series Washing Machine Electronic Control Replacement Guide to replace the machine’s motor control board.
Faulty Tub Motor
If the washing machine continues to not agitate or spin, its drive motor may be faulty. This is not a common problem and all other parts related to this problem should be investigated before replacing the motor. If the motor is visibly damaged, it will most likely need to be replaced.
Questions other people have asked about this
- Why won't my washer spin or drain?
- Why will my washing machine not agitate?
- Loud clicking during agitation cycle
- Washer won't spin or agitate
- Removing the agitator assembly
- How do I take out the agitator? There is a shirt stuck underneath
- Why does the washer sound like its spinning but it's not?
- Why won't my washer agitate? I hear it humming but does not agitate.
- The washing machine fills with water and then does not agitate.
- My Kenmore washer won't spin.
- Washer stops agitating after a couple minutes.
- Agitates in short movements, not regular movements
- Won't agitate or spin on a normal cycle but will on drain and spin
- Kenmore washer aggitating but not spinning
- Why is the agitator not agitating?
- Washer doesn't agitate or spin, but will drain.
- Won’t agaitate or spin
5 Yorum
I just wanna no how put tub into place & lock it down??????
John Vassa - Yanıt
Moror hums but does not turn
James Pemberton - Yanıt
Moror hums but does not turn on
Clothes soaked at bottom..still spinning?
Vanessa Hart - Yanıt
Drive shift is broke to to replace
Debra Lewis Williams - Yanıt
