lens obstruction error help
i have a problem.my camera is a kodak pixpro az251 i'm getting lens obstruction error trying to figure out howv to fix it .asking to re-start camera nothing happens.can someone help.ty in advance
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
tornadoman1955 it is entirely possible that this is caused by a stuck lens. Follow these attempts and see if you are getting somewhere. If not, it is most likely you will need a new lens assembly.
Bu yanıt yardımcı oldu mu?
Mine is stuck out what should I do about this?
@Blair B. same situation,same link just stuck on the track for the retraction. If the link does not provide a good solution for your camera, you will have to replace the lens.
Hi,I bought a Kodak pixpro AZ252 camera from Walmart and I put the batteries in and also a
(PNY Elite 16GB SD Card) and when I turned it on it said Lens obstruction Re-start camera and I don’t know what to do or how to can you guys help me!
Mine is doing the same thing!
Same here, just got it today, charged it and can’t even use it.
My Kodak camera has an obstructed lens and I dont know what to do. Please help!
Son 24 Saat: 13
Son 7 gün: 111
Son 30 gün: 438
Her zaman: 29,573
