Ana içeriğe geç
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Pinout for Charing port
Hey all does anyone have a pin out of the usb charging port on the Ipad Mini 2?
https://s19.postimg.org/6t657c3jn/Screen...
Bu iyi bir soru mu?
Puan 0
2 Yorum
Is this on logic board?, if the pin is missing u need scratch, to make new pin
tarafından
i dont even know what pin(s) are needed - thats what i need to find out.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here is a image that shows where you have to connect the missing pad. Look for the red :>)
Bu yanıt yardımcı oldu mu?
Puan 3
3 Yorum:
So the red dot is also power from the usb connector since it seems I'm missing those 2 red pins?
Also, what would the ground be located?
tarafından
To find ground, just put one multimeter probe on a shield and then use the other probe to check the pins individually. Then look for 0 Ohm readings or a beep in continuity mode.
tarafından
Thanks @Minho. This pin for power would be the one that allows it to be charged as well, correct?
tarafından
Yorum Ekle
Yanıtını ekle
David sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 26
Her zaman: 594
