Ana içeriğe geç
Asus X555L, Mayıs 2015'te piyasaya sürülen düşük bütçeli bir dizüstü bilgisayardır. Bu kılavuzlarda gösterilen model, tüketiciler için uygun fiyatlı olacak şekilde tasarlanmış bir Intel Core i3 dizüstü bilgisayar olan X555LA-SI305041'dir. Benzer model numaraları: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN ve X555LP
Factory Reset Gone Wrong
My laptop was being very slow, to the point where i simply couldn't open two applications at once. I decided to factory Reset the whole thing, i've done this previously on other laptops so i didn't see the problem. After the reset i closed down the laptop and left it for a few weeks. I tried to go on the laptop in question yesterday and it is not accepting the password (I haven't changed the password and i am certain of what it is). The password hint has also changed, it is missing letters and words. I have tried to create a password reset disk using another computer and this has still not worked, it throws up errors when i try to reset my password. I am totally lost on what to do. The F8 and F9 button seem not to work or respond and I feel like i have tried everything obvious. There is no way of getting into the laptop but it looks totally fine.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi ,
Since you've already done a reset once, try doing it again.
You've got nothing to lose except a bit more time.
Bu yanıt yardımcı oldu mu?
Puan 2
5 Yorum:
I can't get onto the system to do another reset, It was my first thought but theres no way how. Any ideas?
tarafından
Try using a Win 10 recovery USB and boot from it to reset the laptop.
The USB recovery drive can be created from any known working Win 10 PC. Go to Control panel > recovery > Create USB recovery drive
You'll need 8GB flashdrive and 40-60 minutes of time.
Don't forget to enable USB legacy or CSM in BIOS settings of laptop and alter boot option to USB drive as 1st option.
tarafından
How do I do the last part?
"Don't forget to enable USB legacy or CSM in BIOS settings of laptop and alter boot option to USB drive as 1st option."
tarafından
The F9 key won't work at all.
tarafından
Hi,
For your laptop press F2 during POST. i.e after laptop starts and before Windows boots to enter BIOS setup.
p.66 of the User Guide
You have to get the timing right. If too early the PC will beep at you and stop. Let go the F2 wait 0.5 sec and press F2 again. Another way is to continually keep tapping F2 until you see BIOS screen.
If pressing F2 too late and Windows starts to boot up, press and hold Power button until laptop shuts down and then start again.
You can also change boot order in BIOS
tarafından
Yorum Ekle
Dose the machine boot into windows, in other words is it a windows password ? or is it like a Bios password ?
If its running windows 10 it may have switched to your microsoft account. try the password of that.
Puan 0
2 Yorum:
I've tried the windows password and it won't accept this.
tarafından
can you take a photo of the password screen your seeing and upload it here ?
tarafından
Yorum Ekle
Yanıtını ekle
sally wall sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 3,800
