Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
Black Screen After Screen Repair
I have just fixed an iPhone 6's screen for a Cutomer. And the screen is black. It works because iTunes recognises it.
Tried the old screen and also another screen and none of the 3 screens work.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
You may have blown the backlight circuit on the logic board. To be certain, shine a bright light on the screen after you connect it to an iTunes enabled computer. If you see a dim image, then the backlight circuit is damaged. This will require a micro-soldering repair.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
That's the thing, the display shows nothing! Yet iTunes recognises the phone. I have no idea what the issue could be.
tarafından
Then you will need to look at the LCM Driver circuit (Chestnut).
tarafından
Yorum Ekle
is there image and no backlight ?
Puan 1
1 Yorum:
The backlight doesn't work either
tarafından
Yorum Ekle
Take Diode Mode readings of the FPC's and compare to 1st image, check Filters for continuity...For backlight, pay attention to image 2, and for image, you can start with 3 - 5, but may also find LCM Reset, Photon alive, etc while looking through diode mode readings if off...
Puan 1
Yorum Ekle
sounds like you blew the backlight 99% of the time that happens because the battery was not disconnected during the repair
Puan 0
4 Yorum:
Oh crap! How do I fix that?
tarafından
you have to change the filter are you good with microsoldering?
tarafından
I'm not good with it no. I don't even have the right equipment
tarafından
where are you located? check shops around you or you can just send it in
tarafından
Yorum Ekle
Yanıtını ekle
Benjamin Poli sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 124
