Ana içeriğe geç
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 Soru Tümünü görüntüle
My ipad still wont turn on after I hard reset
There’s no display on my ipad mini2. I can hear sound coming from it. I hard reset it, but the apple logo only appears split second. I decided to reset it to factory setting by connecting it to itunes. I reset it successfully but my screen still wont turn on
Bu iyi bir soru mu?
Puan 0
1 Yorum
Hmm, could be the cable's fault, I don't think you'll be able to repair this yourself (This is very risky and could cause in your iPad not working at all), you could take it to a repair shop or the Apple Store and see if they can fix it.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Plug your iPad into an iTunes enabled computer and then shine a bright light on the screen. If you see a dim image, the the backlight is no longer working. This could be a problem with the LCD or with the drive circuit on the logic board. Has you iPad been repaired or dropped recently?
If you can't see a dim image, then the problem is most likely with the LCD. The iPad is a more challenging DIY repair so check out this guide to see if you want to try repairing it yourself or not.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Puteri Nabila Hamzah sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 1,838
