Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
Screen Not Working After Replacement
Hello all,
I just replaced a screen on an iPhone 6s, and after I put the screen on, it won't light up showing me it's on. I can hear the little reminder noise, so I know that the phone is on. I have put the old screen back on, and the screen still won't turn on. I have tried disconnecting the battery and reconnecting it, but it still hasn't solved the problem.
Does anyone know what's up with this phone?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
If the screen got replaced while the battery was left plugged in the backlight circuit is probably blown which can only be fixed by microsoldering.
Some repair shops do board-level repairs / microsoldering which you may be able to find locally in your area.
What usually happens is when you disconnect or connect the screen while the battery is still plugged in you may see a puff of smoke coming from the screen connectors meaning the backlight filter blew up.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Could be that you got a defective screen, it's about 1 in 10 screens that I replace are non-functional. Also there is the possibility that the backlight blew.
Puan 0
Yorum Ekle
99% your backlight filter is blown!
http://mendonipadrehab.com/entries/gener...
Puan 0
Yorum Ekle
Yanıtını ekle
Benjamin Gabriel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 854
