Ana içeriğe geç
The Dell Inspiron 11-3147 is an 11" laptop-and-tablet hybrid device. The screen can fold onto its back to allow for handheld usage. It was manufactured in August 2015 by Dell.
13 Soru Tümünü görüntüle
Do you think I can safely try to install 8GB of RAM into this laptop?
Hello everyone, I have read somewhere that Dell purposefully reprogrammed their BIOS so that they could set limits on any upgrades their customers could install. I won't be buying Dell or any other manufacturer that limits my ability to upgrade.
Anyway, on the official Dell website they say my laptop only supports 4GB max. But on a different website it says that my processor supports an 8GB max. Then on another website a user posted that they were able to install an 8GB upgrade.
So what do you thing? Should I just buy the RAM and try to install it? Or will I destroy my hardware poking around in there?
Bu iyi bir soru mu?
Puan 0
1 Yorum
I shouldn't have said that I won't be buying Dell. I bought another Dell because it beat the price of the competitors. I made sure I have plenty of RAM so I can do my work.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @abraham_luna
Dell might state that it supports only 4GB for stability reasons. I don't know.
As long as you don't exceed the speed (1333MHz ) and ensure that it is DDR3L then you should be OK, barring accidents when you install it that is. Try a 8GB SODIMM stick and see if it works.
Here are the memory specifications for your laptop (as you most probably already know)
Memory:
Slot : One SODIMM slot
Type: DDR3L
Speed: 1333 MHz
Configurations supported: 4 GB
Here is a link to the service manual for your laptop. Scroll to p.17 to view the necessary pre-requisite steps and then the procedure to remove / replace the RAM
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
8 GB works fine in my laptop. Now im wondering if 16 will work
Puan 1
3 Yorum:
Thanks for your input. I replaced this laptop with a newer one last November and I have plenty of RAM.
tarafından
Hi! I'm curious if you really have Dell Inspiron 11 3147? And what are the specifications of the 8GB RAM that you installed? Thank you!
tarafından
8GB 204-Pin DDR3 SO-DIMM DDR3L 1600 (PC3L 12800) Laptop Memory
tarafından
Yorum Ekle
8 is totally fine, I did successfully…
Puan 1
1 Yorum:
hi..specs of the ram please? thanks
tarafından
Yorum Ekle
Yanıtını ekle
Abraham Andres Luna sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 1,580
