Ana içeriğe geç
The iRobot Roomba is a robotic vacuum cleaner. The 805 model was released in 2013.
What is charging error 5
why does the charging error 5 come on when my rumba 805 is charging
Bu iyi bir soru mu?
Puan 4
2 Yorum
I hv removed battery, clean dust h wipe but charge error 5 still showing.
tarafından
Hello!
Check out this roomba charing error solution: https://www.errorcodeshero.com/roomba-ch...
It was a big help to me.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
It means your Roomba isn't charging correctly.
Here is a link that provides some information along with some troubleshooting: https://homesupport.irobot.com/app/answe...
Bu yanıt yardımcı oldu mu?
Puan 0
7 Yorum:
I've done all these things and also charged the Roomba directly by pulling the cord out of the docking station and plugging it directly into the Roomba but I still get Charging Error 5. I've bought 2 new batteries, one from Ebay and one from Amazon and still get the error message.
So its not the contacts, the battery or the docking station. The roomba will charge for about an hour and then repeat the error message and red lights. If operated manually, it will work for an hour + and dock. However it will not operate to its automated schedule.
Any suggestion on where to go from here?
tarafından
Error 5fixed! We did everything, pulled apart, wiped over, changed batteries twice to no avail. By this time Roomba was completely dead, no lights. And then we changed the power transformer. Yay! Lights on and it went into about 6 hours of a quick amber flashing refreshing cycle. We left it a further 12 hours before using it....and it is better than ever! Such a relief
tarafından
We did all of the above AND changed the power transformer. After a few hours of charging... The charging error 5 returned. I am now trying the reset, which is done by holding the power button for 10 seconds. Will update with results afterwards.
tarafından
Always look at the steps and then change up. Remove battery, do not put battery back in!, then plug in. It should not go to error 5. Mine went to error 1.
tarafından
@MDavis so how did it go? You said you would update with results and I've been waiting...lol. HELP!
tarafından
2 tane daha yorum göster
Yorum Ekle
I found holding that you need to reset it for around 30 seconds, not 10 as some suggest. I did this 3-4 times whilst it was charging as the charge error kept occuring. This happenwd over the course of a few hours, but then it continued to charge and is now working.
Puan 0
2 Yorum:
Holding what brother, HOLDING WHATTTTTTT
tarafından
Pcb of charge station got a 470uf bad according to a YouTube video, but not my case, I opened it, no such cap on my board
tarafından
Yorum Ekle
Yanıtını ekle
elaine sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 79
Her zaman: 49,287
