Ana içeriğe geç
Acer tarafından 2015 yılının ortalarında satışa sunulan, orta segment, uygun fiyatlı bir dizüstü bilgisayardır. Bu dizüstü bilgisayar Nvidia 940m grafik kartı, Intel i5-5200U işlemci ve 1080p ekran ile gelmektedir.
My laptop boot problem
It is saying that it is restoring previous version of Windows
It is restarting again and again
Please can you fix for me.......
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Hi dawn tom
Are there any important data in it?
It could be OS issues (Crashed) or HDD issues.
Any symptoms or changes you had done or noticed before this happened?
I suppose the current windows is running on win 10 ?
tarafından Paylaş
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Just download a windows iso file from any site or just click the link i have provided and make bootable pendrive with it. Use this USB to install new windows to your PC. Now you can reset all the things in your computer from start.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
If you did not ask it to restore previous version, Windows is running into a problem with the version installed.
It could be a bad file, corrupt HDD, bad driver, or incompatible hardware.
It may be possible to boot into safe mode. If so, then you can try to run CHKDSK C:
That looks for and tries to fix problems on your HDD.
After that, you can try to run SFC /scannow.
That looks for corrupt system files and restores them if found.
Both of those must be run in a command window. Click Start button and type CMD then click on the answer.
If you can't boot into safe mode, the only option is to reinstall Windows as mohit pointed out.
However, if you have unbacked up files on your HDD, you will need to remove the HDD and connect it to another computer to remove them b4 installing. That may or may not be possible if there is a more serious issue with the HDD. If so, you may need to replace the HDD.
Then back to your computer and do a clean install. An update install might work and would negate having to reinstall all your programs. It depends on where the problem is. A problem in the registry might be carried over in an update install.
If you are unclear about Windows clean vs update install, google it.
Puan 0
Yorum Ekle
To fix Unable to Detect Registered Biometric Device
Puan 0
Yorum Ekle
Yanıtını ekle
dawn tom sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 923
