Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Soru Tümünü görüntüle
Screen damage pressure? White spot
My iPhone 4 has a white spot in the middle of the screen, well is a spot wich is whiter, this can only be seen if you have a white backgroud, so when you have dark colors on the back you dont noticed. I got worried about this and i pressed harder the spot and the screen went kinda purple on that very spot, so im guessing is a damge for the pressure this spot, please help me, dont know what to do, thanks
Bu iyi bir soru mu?
Puan 4
1 Yorum
My phone Alcatel PIXI 4 has a white spot everywhere on the screen. Please help me to solve this kind of problem. Thank you
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
It sounds like there is a slight dip or imperfection on the back side of the digitizer. It is collecting more light from the backlight. If it is under warranty take it in for repair. They may exchange it so I would back up your information on it. Digitizers are not made to have above gentle touch pressure. The touch screen is glued directly to the LCD I would imagine you would get a kind of purple color pressing firmly on it, since that is the native color of an inactive LCD. If it is not under warranty and not interfering with reasonable normal use I would live with it. If you can't do that you will have to replace the screen assembly. The instructions for replacing your screen are here. New screen assemblies are here.
iPhone 4 (GSM/AT&T) Screen Görseli
Ürün
$24.99
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Look at this video. Screen replacement is expensive solution before that you should try some tricks like these. https://www.youtube.com/watch?v=PxUOlqaN...
tarafından
Yorum Ekle
I also have a problem like this. There is a yellow/green/purple spot on my display.
iPhone 3GS, iOS 6.1.6
Also, try not to press on it. You may make it worse...
Puan 0
1 Yorum:
It may be something up with the digitizer, as ABCellars said.
tarafından
Yorum Ekle
The only solution for this is screen replacement? no other way?
Puan 0
3 Yorum:
you may have a case that is too tight. the bright white spot happened to me and as soon as i took the case off (after reading this) it went away
tarafından
Thanks ,taking off the case worked !!1
tarafından
did it went out right away?
tarafından
Yorum Ekle
Once try refixing the Digitizers (display) and while fixing do not over tight the screws
Puan 0
Yorum Ekle
Yanıtını ekle
Rafael sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 39
Her zaman: 150,308
