Ana içeriğe geç
This 2012 K410 model of the Lenovo K Series desktop features a three speed power control switch and a 3rd generation Intel Core processor. Its high preformance graphics capabilities make it an excellent choice for gaming.
Why is my computer not loading?
Every time i turn on the PC it says “preparing automatic repair” then a little message pops up with a blue screen stating that my PC did not start correctly. It then gives me several options to fix the problem and I have tried them all and nothing is working
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
What version of windows are you using and do you have a disk for it? Some things to try before going overboard on running repair programs . First unplug the computer so it has no power then hold the power button down for a 60 second count . This will allow for a clean boot . Next if this brings no joy boot into safe mode(would tell you how if I knew which version of windows you are using) with command prompts then run an sfc scan this will repair most files and if not it will prompt you to run the repair disk . If it will boot in safe mode run a virus scan as many viruses emulate a system failure . Something else you may want to try is removing one stick of ram and running only one if no joy try the other one . Bad ram caan cause a blue screen error. Hope this helps
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Vcampbell sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 321
