Ana içeriğe geç
The Chevrolet Silverado, and its mechanically identical cousin, the GMC Sierra, is a series of full-size and heavy-duty pickup trucks manufactured by General Motors and introduced in 1999 as the successor to the long-running Chevrolet C/K line. The Silverado name was taken from a trim level previously used on the C/K pickup truck from 1975 through 1998.
130 Soru Tümünü görüntüle
Rear brake lights, turn signals, and back up lights not working
I have a '98 Chevy Silverado K1500 that's having rear light issues. The brake lights, turn signals, and back up lights stopped working. It doesn't matter if the lights are on or off. However, when I turn the lights on, my tail lights come on and stay on until I turn them off. My third brake light is also working regardless of the lights being on our off. I have checked the fuses under the dash and the few under the hood as well as replaced all the rear bulbs with no improvement. Any ideas, suggestions, or solutions?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
3 Yorum
Have you figured the problem out? Having the same issue trying to figure it out !
tarafından
I have 1999 chev suburban I have running light all the way a round brake and turn on all but right rear I have replaced the light bulb and the board and the turn relay flasher and still not working on my right
tarafından
Anyone happen to find out the solution? I just bought a 94 k2500 suburban that doesn't have any rear lights other than running lights and can't find out what the issue is.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@cornbread1972 to many lights that are not directly connected that are not working. You do want to check the rear light assembly and check for good ground on it. Check for corrosion and double check the wiring harness. Check with a multimeter if you get power to the individual cables.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
1999 silverado
tarafından
No lights at all running reverse then or backup
tarafından
@Brian Knuth you checked the answer and followed the schematic?
tarafından
Yorum Ekle
I have no running lights on a 96 Chevy truck
Puan 0
Yorum Ekle
Yanıtını ekle
David Ewing sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 58
Son 30 gün: 192
Her zaman: 19,521
