Ana içeriğe geç
2015 Mart ayında duyurulan ve 10 Nisan 2015’te piyasaya sürülen Galaxy S6, Galaxy serisinin önde gelen ürünüdür. Kavisli ekran versiyonu Galaxy S6 Edge olarak bilinir.
487 Soru Tümünü görüntüle
camera black spots in photo
my camera lens was brooked cuz it fall from my pocket however when i am launching back camera i see black spots randomly across the photo i just took .
what is the main cause of this problem and how can i fix it ?
will am i need to change my camera or just the lens cover ?
is s6 edge plus camera fits s6 or not
another question i cant find s6 speaker so if i buy s6 edge would it work on my phone
Bu iyi bir soru mu?
Puan 1
2 Yorum
Sounds like there's some dirt or something in the lens. Clean it out, if that doesn't fix it then most likely will need a camera replacement.
tarafından
I fixed a similar problem in my Sony Z2 by removing the dust cap nearest the camera lens. This problem was a spec of dust either inside the lens or on the sensor. I then tapped the phone on my work bench. Then I blew into the slot. Turned the phone back on and the spot was gone. PS the lense maybe foggy for a minute or so as a result of the blowing but this quickly cleared.
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
The black spots when using the rear camera is caused by dust going inside the lens. You could try cleaning it out with something like a air compressor but you will be lucky if you are able to clean inside the lens.
You will need to replace the rear camera along with the rear camera glass at the same time to fix that issue.
S6 edge won't work on S6 as far as I know because they are slightly different in size to fit in.
When buying a rear camera make sure it is compatible with your model first.
You can either buy the mid frame which comes with the speaker or just the speaker itself meaning you will need to transfer the new speaker into the midframe.
Personally I would replace the whole midframe to be safe, also make sure that is for your model number of the phone as there are different variants for that too.
Here's iFixit guides if needed:
Samsung Galaxy S6 Ara Çerçeve Takımı Değişimi
Samsung Galaxy S6 Rear Facing Camera Replacement
Samsung Galaxy S6 Ara Çerçeve Takımı Görseli
Kılavuz
Zorluk:
Zor
30 minutes - 1 hour
Samsung Galaxy S6 Rear Facing Camera Görseli
Kılavuz
Zorluk:
Zor
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Just shake your phone, will help. :)
Puan 0
Yorum Ekle
I put my mouth over the lense and blew a few times as hard as possible. Strangely worked and the black mark has gone.
Puan 0
Yorum Ekle
I had the same problem,
Just take the phone into the bathroom with you and have hot shower, the steam should draw the dust out of the lens.
worked for me
Puan 0
3 Yorum:
I have a black dot showing up in my front facing camera photos and videos but if I use a different camera app it doesn't appear. Any ideas???
tarafından
Same problem with me please let me know too if you have resolved this problem
tarafından
Same issue, after phone A50 fell down got this black spot for front camera,
it appears in my photos, videos..etc even on the screen when i am using whatsapp video call but the other person i am talking to does not get it. He sent a snapshot and there where no spot.
tarafından
Yorum Ekle
Yanıtını ekle
ahmad taha sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 23
Son 30 gün: 134
Her zaman: 49,856
