Ana içeriğe geç
Kenmore Elite HE3, Kenmore tarafından üretilen bir çamaşır makinesidir. Whirlpool Duet ile aynıdır.
What does CL mean
My washer flashes CL when I power on. Will not let me choose cycle and will not start
Bu iyi bir soru mu?
Puan 3
15 Yorum
I had the same problem (CL Code) with my Kenmore HE front loading washer ( Model 796.4168). This Trouble Code is not in the Use and Care Guide provided with the machine. The first deactivate instruction doesn’t work. There is no “drain and spin” button on this machine. When I was reaching over the machine to unplug it (the alternate deactivation instruction) I bumped something on the control panel, heard a beep and the CL code was gone. What did I press to (apparently) reset the Control Lock?
tarafından Paylaş
I had exactly the same problem. Based on your comment, I pressed extra rinse for a few seconds and it cleared the CL. Works again!
tarafından Paylaş
I have exactly the same problem. I unplugged the machine for a period of 20 minutes, I pressed the ‘Chime’ button down for extended period, and still doesn’t reset the error. There isn’t any ‘Spin’ or ‘Drain’ buttons. Do you have any ideas?
tarafından Paylaş
I have the same error, neither of the above solutions worked. I called every company I could. No answers. Help.
tarafından Paylaş
I have a control lock button and held it down and the error code cleared, I think that happens mostly when you accidently lean on buttons when reaching over the panel .
BabyDoll
tarafından Paylaş
10 tane daha yorum göster
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
From Kenmore elite washing Machine Code error CL, control locked?:
This error code most likely indicates that the CONTROL LOCK has been activated. To deactivate the control lock press and hold the drain and spin button for 5 seconds. Or you can try to reset it by unplugging your machine, and plug it back in after 5-10 min.
Bu yanıt yardımcı oldu mu?
Puan 6
3 Yorum:
Hold the chin button down for 5 seconds and it disappears. That’s what worked for my machine. Good luck
tarafından Paylaş
On my machine the chime button is the soil level button with control lock written underneath in very small letters
tarafından Paylaş
Worked for me
tarafından Paylaş
Yorum Ekle
I had the same problem. I tried unplugging for more than 10 minutes. Did not resolve. There is no Drain and Spin button. I pressed and held the Extra Rinse button for a number of seconds. It did clear.
Puan 6
20 Yorum:
I tried unplugging and also holding down the extra rinse button...still CL. I called the diagnostics number, and he said it was locked, so I held down the Chime button for a few seconds and it cleared. Washed is running fine!
tarafından Paylaş
Thank you! It was the Chime button!
tarafından Paylaş
Man I love the Internet… Thank you it was the chime button :-)
tarafından Paylaş
Chime button worked for me too....thank you!
tarafından Paylaş
Pressing the Extra rinse did it for me too. Love this way to get info
tarafından Paylaş
15 tane daha yorum göster
Yorum Ekle
Just below the CHIME button in very small print it says Control Lock. Press and hold CHIME button for 3 seconds to engage and disengage this function. We have a toddler who was the first to discover this.
Puan 2
5 Yorum:
Thank you. I had done this before, but forgot.
tarafından Paylaş
Thank you! We just discovered/noticed the fine print😉
tarafından Paylaş
tried many times but its not working
tarafından Paylaş
could there be any other problem
tarafından Paylaş
My button for the child lock got stuck and would not disengage. I had to take the panel apart and find the corresponding internal part and pressed that. It worked, do not recommend if you have a warranty or fear of electrocution.
tarafından Paylaş
Yorum Ekle
Botton to push on mine was just below Rinse and Spin button...in very small print it says Control Lock. Pushed and held it for 5 seconds and all cleared.
Resim
Puan 0
2 Yorum:
I have the exact same washer as the photo above but none of those options are working for me. It won’t clear.
tarafından Paylaş
@jennifermc66899
What is the model number of your washer?
tarafından Paylaş
Yorum Ekle
Hi @frankholstein
With the machine turned on, you need to press and hold the Rinse and Spin button for 3 seconds to disable the Control Lock option.
See p.22 of the Kenmore 31552 use and care guide.
Control Lock + padlock symbol should also be printed on the panel under the button on the machine
Here's a poor image taken from the guide that may help.
Resim
(click on image)
Puan 0
Yorum Ekle
Yanıtını ekle
Robyn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 49
Son 30 gün: 197
Her zaman: 33,141
