Ana içeriğe geç
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
Cranks and Starts Sometimes
My 2006 Nissan Altima has been cranking and starting but sometimes it would just shut off while I'm driving. Now it will only crank and not start. Someone said I may have a bad fuel pump. How can I find out what the problem is? Are there other things that I can check first since a fuel pump is so expensive.
Bu iyi bir soru mu?
Puan 0
2 Yorum
Hi @gulfport152 ,
Get the OBDII port scanned for codes using a scantool.
Any codes shown will give an indication of what is going on in the engine
tarafından
Thank You so much
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Its most likely the fuel pump. Grab a friend and have them try to start it while you beat on the gas tank. Sometimes that will get the fuel pump to kick on. If it does you will know its a bad fuel pump? You also mite be able to hear it by turning the car on without cranking it.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
I started this morning, but I did get someone to check it out and they believe that it is the Fuel Pump going bad
tarafından
Yorum Ekle
Yanıtını ekle
R. Sumrall sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 399
