'''Jeffrey I''' the thing with Samsung is that they really do not use blink codes. Yes, they do show up but there is no good guide for it. The main question is always how to distinguish if the problem is caused by Main board or T-Con. a. No Video : If the problem is No Video but BLU is on and Indication LED is blinking repeatedly and faster than normal booting, replace the T-Con board.
“Disconnected the power board from the mainboard, backlight did not come on” sounds like a power board issue. Check pin 14 on CNM803 on the power board and see if you have 5V on that. If no it’s your power board. If yes check the mainboard power IC output
L202 : B3.3V
L203 : B1.2V
L204 : B1.1V
L201 : B1.5V
IC203 : 3.3V
IC208 : 3.3V
If you do not have that voltage, its your main board. If you do check power on T-con Board.
- L9(T-CON) : VCC12
- TP_VCC33 : VCC33
change the t-con board. If that does not work, you are looking at possibly a failed backlight array.
Let us know what you get. Also, post some good images of your boards with your question. That way we can see what you see. Use this guide Adding images to an existing question for that.
++'''Jeffrey I'''++ for the T-con board follow this one
TP VCC should be marked on the board.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
3
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
11 Yorum
my samsung does the sams but it's model is pn51f8500 what can i do?
KALVIN MOSLEY tarafından
KALVIN MOSLEY yours is a plasma TV so your issues should be different. You need to give us more information about what it is that your TV is doing (or not doing)
oldturkey03 tarafından
I have the same problem but when I disconnected the power board from the main board the led lights come on could this be a capacitor problem. My model number is UN50JU6500F it's a Samsung Smart tv plz help
Mitch Mitchell tarafından
i have the same problem but if i disconnect the mainboard the backlight will come out fast, but i have returned it in it will turned it off again immediatly... it blinks twice for 5 times also
Gil Makil tarafından
Oh, Jeffrey I, Samsung UA46D6000 is just as bad. Chances are it will also damage the LED. Thank you.
Tuấn Anh Lê tarafından
6 tane daha yorum göster
