Samsung Galaxy S6 Edge Glass Only Repair
The glass on the s6 edge is cracked, everything else works fine (the digitizer/touch panel still works)
Can i just follow this guys video?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Glass only replacements are done by people that have experience in doing LCD refurbishing it's really not doable for the average DIY person.
It requires tools like freeze machine, enclave, LCD mould to get a good finish.
If you were to do it yourself, there is a high chance of damaging the LCD and/or not having a good finish on the screen.
The tools required can cost well over $1,000 to get it done properly and takes a lot of patience to remove the glass without damaging the LCD.
You are better off replacing the whole screen assembly together as one piece.
Bu yanıt yardımcı oldu mu?
buy lcd with frame used and original try to get a pulled from a working device one.. oem used will be the best bet.. get it according your carrier (dont just get any one) if its Verizon g925v if its Tmobile g925t ect.. p for sprint and a for att.. will cost u about 130.. sell the good lcd bad glass you have (buy back will be 20to40).. and you will install it fast and easy with a tutorial with out damaging anything (well maybe the backglass, not for beginners ether).. good luck!
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 3,438
1 Yorum
Thanks guys!! I know the easiest route is just replacing the entire LCD screen, but the cost of one is just as expensive as an entire phone, i figured to make this as cheap as possible and replace the glass only.
Jason tarafından
