Ana içeriğe geç
Apple'ın 13 inç MacBook Air modelinin Mart 2015 güncellemesi, beşinci nesil Intel Core i5 ve i7 işlemciler içeriyor; bu da performans ve pil kullanım süresinde küçük bir artış sağlıyor.
Sleep Sensor/ Lid Sensor Location
Currently working on a customer's MacBook which apparently had water damage. Anyway, it keeps going into sleep mode unless I connect it to power and external monitor. Sometimes it realizes the lid is still open then switches back to the MacBook screen. Was wondering if anyone knew where the close lid switches are? I ordered a new upper case thinking the sensors were in there some where but it doesnt appear that addressed the issue.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The sensor is on the daughter board, next to the ports there is a thickened PCB with a magnetic sensor on it.
Although I can’t say for water damage, you have to trace the wiring all the way to the SMC to find potential damage that is latching the signal.
Bu yanıt yardımcı oldu mu?
Puan 5
3 Yorum:
When you say daughter board, you arent referring to the I/O board where the MagSafe connects too correct? But instead the area where the MacBook screen cable attaches?
tarafından
Just the magsafe part.
tarafından
Thank you! For some reason, I didn't check on the underside of that piece and sure enough when I flipped it over it was corroded out. I ordered another one so hopeful the replacement will fix the issue.
tarafından
Yorum Ekle
Yanıtını ekle
Devin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 4,085
