Ana içeriğe geç
Repair guides and support for electric and gas-powered high-pressure sprayers sometimes referred to as power washers.
38 Soru Tümünü görüntüle
Pump always on, lower pressure, water leaking
I have a Kärcher K 2.01
Recently, when turned on (= electricity switch on) but without pulling the trigger, it started to "kof", that is to turn its pump on and make the same noise as when you use it, but even when idle.
It did so in short bursts for a while.
Now, the pump is always on, even when you don't pull the trigger, there's a little less pressure (though still usable) and you can see quite a lot of water leaking out of the yellow box.
Is this repairable?
If yes, how?
Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Obtain a ‘Piston seal’ repair kit and renew the three seals. The water is leaking past the seals and causing a drop in pressure. While it’s apart renew the large ‘O’ ring body seal too.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
John Washington sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 155
