Ana içeriğe geç
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
309 Soru Tümünü görüntüle
Check lint filter light is blinking and dryer won't run.
No matter which setting I choose , the check lint filter light starts flashing and the dryer won't start. I have reset the breaker, unplugged the dryer, cleaned out the filter and the vent in the back. An answer on another of this question said to check the heat sensor which I will do. Is there anything else to check for?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
14 Comments
Have you made figured out whats wrong yet? Having the same problem..
tarafından
Anyone?
Marjie
tarafından
Same issue~~~any suggestions??
tarafından
Anyone? Same issue........
tarafından
An obviously common annoying problem - Don't make em like they used to!
tarafından
9 tane daha yorum göster
Yorum Ekle
10 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Check out the answers of the question and see if you find a resolution:
check lent filter light on and will only run on express dry
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I am an appliance installer and had this same issue today. I had found out that I forgot to reconnect the plug going to the door. So the dryer thought the door was open. If anybody has done any work to it that might be the issue. Or could even be a bad switch for the door closed sensor.
Puan 1
Yorum Ekle
Have you checked to make sure the sensor isn’t being blocked or has been unplugged? Find a maintenance manual for your specific dryer and take it apart IAW the maintenance manual
Puan 1
2 Comments:
Late reply, but for everyone replying “Same issue” have y’all checked the sensor? There might be something on the sensor itself, or a short in the sensor wiring
tarafından
2021- same problem. Both the line and the water collector lights are showing/flashing
tarafından
Yorum Ekle
I pushed the door sensor switch in a few times, closed the door tight and seems to have solved the problem.
Puan 1
1 Yorum:
I also pushed the door close switch several times and the dryer started working. Looks like I may need to replace the switch down the road, the contacts are probably degrading over time.
tarafından
Yorum Ekle
I woke up early to tackle this issue, with no luck with all that I tried. My wife came down and turned the dial to Normal and it worked fine. I guess the dial was on sensor mode.
Puan 0
1 Yorum:
I think these machines have a short or maybe defective, I disassembled it and found that pulled in a dryer sheet very close to the motor coil, which is a serious fire hazard
tarafından
Yorum Ekle
Mine wound up being a broken belt. Put a new belt on for $8 on ebay. Light not on anymore.
Puan 0
Yorum Ekle
I just watched a you tube video I have a kenmore he5 elite with f-01 code if you remove circuit board and look at back it blows out a solder joint. I soldered a jumper and fixed mine. I’d you can search enough there is a video of this on you tube
Puan 0
1 Yorum:
I watched a you tube video if you pull circuit board and look at back blown solder joint soldered jumper wire fixed. There is a you tube video on it. If you pull circuit board out of plastic box and see a burnt spot this is it. So happy
tarafından
Yorum Ekle
I had this issue after replacing the idler pulley and vacuuming out a whole lot of lint from inside the machine. There is a little white switch just below the belt drive that had a piece of lint stuck in it and holding the switch down. I removed the lint and, voila, it's running again.
Puan 0
Yorum Ekle
First , I turned the power on to the dryer
Second. I removed the lint screen from the slot .
Third, I then pressed the start button with the lint screen still removed .
Finally, the dryer started right away without any error or resistance to start
After the dryer was on , I slid the lint screen back into placed
Puan 0
Yorum Ekle
I had the same issue.
I would touch the mode I wanted then the start button and then the light would blink but never start.
Until I hit the start button a second time and then the dryer started up!
Hope this helps.
Puan 0
Yorum Ekle
Yanıtını ekle
Dean Wurtz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 41
Son 7 gün: 230
Son 30 gün: 1,016
Her zaman: 42,010
