Ana içeriğe geç
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
Slight Screen Repair Issue
Hey there I was attempting to take the digitizer off my badly shattered iPad Mini 1 Space Grey and it was cracked so badly there are still chunks on it in really tiny pieces any ways I can save it so I can successfully put the new digitizer and LCD in thank
Ps if you can’t visualize I can add a photo
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You'll have to scrape them off, with some form of flat tool. Try putting some IPA or Acetone on them first to soften up the adhesive. Once that is done, you'll want to remove all of the adhesive from the frame (use IPA/Acetone again) before putting the replacement digitizer back on.
Some replacement digitizers have poor quality adhesive pre-installed so you may want to consider applying a high quality adhesive such as this one.
Custom cut rolls of Tesa 61395 double-sided tape for repair. Görseli
Ürün
Tesa 61395 Tape
$5.99
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thanks I’ll try that ipa has solved so many issues before
tarafından
Yorum Ekle
Yanıtını ekle
Ben Cybulski sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 54
