Ana içeriğe geç
K56CM, Asus tarafından üretilmiş 15,6 inçlik bir "ultrabook" dizüstü bilgisayardır. İlk olarak 2012 yılında duyurulmuştur.
Computer suddenly turning slow
I could not find the model list for my laptop, but I have an Asus k501U
- Intel core i7 6500U
- 8GB RAM
- 1TB HDD + 128G SSD
- Intel Integrated graphics + Geforce FTX 950M
I was playing league during the night in a hot room, so my laptop has reached a pretty high temperature. However, my game was smooth and laptop was still running smoothly. After I shut it down for the night and boot it up the next morning, the entire laptop turns extremely slow and freezing. Anything I try to open will take minimum 10 minutes and become unresponsive. I downloaded Throttlestop and noticed I have the "thermal" limit under CPU and GPU and ProcHot was activated. I unchecked the Prochot box and cleaned my laptop's fan, but that hasn't made anything faster. I have also ran multiple Malwarebytes and found nothing and did a CCleaner, but still the same result.
Please help, how does my laptop suddenly turn permanently slow like this and how do I go back to its original speed. Any help is appreciated, thanks!
Bu iyi bir soru mu?
Puan 0
1 Yorum
Hi,
Check in Event Viewer (right click on Win start button - left side of Taskbar- and click on Event Viewer link) to see if there are any Critical, Error or Warning events listed that may give an indication of some problem
Try starting the laptop in safe mode (assuming you have Win 10 installed) and see if the performance improves.
If it does it points to a software problem, if it doesn't it is most likely hardware related.
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
There is a good chance that you have dried out the thermal paste that resides on the CPU itself. This is the way that heat is transferred from the CPU chip to the heat sink. The laptop needs to be opened up and the thermal compound replaced on the CPU. That may resolve the problem. When the CPU gets hot, it will throttle itself to a slower clock speed which will generate less heat then normal speeds.
Try replacing the thermal compound and update this with the results.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Rebecca Lai sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 30
Her zaman: 3,541
