Ana içeriğe geç
Announced in August 2017, the Galaxy Note8 is the successor to the recalled Galaxy Note7. The Note8 was made available to the public for purchase in September of 2017.
My S Pen broke off, half still inside, how can it be removed?
Help get SPen out of phone?
Bu iyi bir soru mu?
Puan 4
2 Yorum
I used a lock picking tool it had a hook on It tried for 30 min then I prayed put it back in felt it move and out it came .
tarafından
Grateful it worked
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Smack the bottom of your phone or lightly hit it on a table, it should come right out when you shake it!
Bu yanıt yardımcı oldu mu?
Puan 10
6 Yorum:
This worked for me, thanks.
tarafından
purrrrfect solution , thank you
tarafından
Worked for me too thanks!!
tarafından
This worked thanks alot. ?
tarafından
Worked great for me. Thanks!
tarafından
1 tane daha yorum göster
Yorum Ekle
Tweezers? Here is a video of someone getting one out:
https://www.youtube.com/watch?v=zA5xYT-x...
Puan 1
1 Yorum:
My S pen broke outside phone and i put it back in there Not thinking. The pen came out but part of the plastic encasing remained inside. How can I get this to come out?
tarafından
Yorum Ekle
Mine was stuck way inside the phone. I used a drill with a tiny drill bit and drilled into the hole in the stuck s pen. All you have to do is simply pull it out. It ruins the s pen, but you can get a replacement on Amazon
Puan 1
2 Yorum:
you can use a phillips screw driver and insert it inside. it worked best for me to take out the broken s pen inside.
tarafından
Yay! the screwdriver is the only thing that worked for me! thank you so so much!
tarafından
Yorum Ekle
I used the old-type iron twist serving to prepare a hole in the wood plate for screwing-in the screw. I think this is the best solution!
Puan 1
Yorum Ekle
Yanıtını ekle
Robin Kamps sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 64
Her zaman: 23,192
