Ana içeriğe geç
MacBook Pro models with a 15" display
8251 Soru Tümünü görüntüle
Replacement LCD not working, rainbow colored vertical lines
My original LCD cracked so I ordered a new LCD for model A1286. Having replaced the LCD I now only get a white background with rainbow colored vertical lines covering most of the center of the display.
Concerned that this was an issue with my disassembly I reconnected the old (cracked) lcd and it is still working perfectly (apart from the crack). Therefore I don't consider this to be an issue with the connections.
Connecting to an external monitor still works. I also tried resetting the PRAM and PMU but makes no difference.
Any advice for next steps would be greatly appreciated.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Since your old LCD works and the new one fails, I have to think the LVDS cable is OK. Check to see if the new LCD is the same brand and part number as the old one. If they are identical, I would say the new one is defective. Check the reputation of your supplier, was the part new or used?
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Paul Solomon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,626
