Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Soru Tümünü görüntüle
iPhone deactivated after screen-replacement, "try again in 12k mins"
Hi
I changed a screen for iPhone 4, and when I turn it on, it says "iPhone is deactivated, try again in 21 713 164 minutes".
I have never experienced this before, do you have any answers to why this happens - and what to I do ?
Bu iyi bir soru mu?
Puan 1
2 Yorum
I'm sure there are similar posts and solutions to this with ipods.. try searching the solutions on ipods with key words like "minutes"
tarafından
My iPod touch is disabled.. solutions to these apple devices is often similar (i know you have an iphone4.. I'm not quite senile yet)
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sounds to me like your iPhone is deactivated due to a wrong passcode entered check Apple's Solution first. as in way i honestly do not know. Since I think it's the Passcode lock,simply restore in Recovery or DFU mode
If you connect the phone to the computer it is synced to it will unlock the phone. You will still need to enter the pass code to get in but it will reset the time. Or you can try to restore your iPhone in DFU mode. Open iTunes and connect the iPhone via USB.
Press and hold the Home button and the Sleep/Wake button at the same time. Continue holding the both buttons for 10 seconds. Then release the Sleep/Wake. Keep holding the Home button until iTunes pops up that it has found an iPhone in Recovery Mode. Your Screen should be dark. Sometimes it may take a few attempts to get the iPhone into DFU mode. There is more info on here You should now restore your iphone. Of course always make sure that you triple check your work for any loose connections, cables not properly seated etc....Good Luck
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
thanks a lot mate.i replaced a new screen in iphone 4s.i had that issue and with ur solution its done.thank you
tarafından
what did you.do. help please
tarafından
oh nevermind i need help i.dont have access to.a computer i know the code it worked at first then allnof a sudden it stopped
tarafından
Yorum Ekle
Yanıtını ekle
Erik sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 5,758
