iPhone 5s restoring gives error 2015; screen is broken
I have an iPhone 5 that I got from someone, because he dropped it and the screen broke pretty heavily. Quite a bit of the glass in the top right corner is completely gone. And he couldn't boot it anymore either.
However, I might be interested in fixing it. Question is though, how much do I have to fix?
Current symptoms;
- When I received it, you could turn the phone on, but it wouldn't actually boot. Instead, it would reboot constantly.
- I tried connecting it to my Mac and doing a factory reset on it through iTunes. However, after wiping the system, that fails with an 'unknown error (2015)'. This happens on all my restore attempts.
- Now, connecting it to my computer shows 1) the Apple logo, and then 2) the image asking to connect it to iTunes.
Restore sequence;
So my question is; does anyone know if just replacing the screen would work?
Or do I have to replace something else as well?
Bu iyi bir soru mu?
4 Yorum
Same here i got the iphone from my sibling he said that the phone turn off and it reboots and even it is charging the iphone reboots the phone has a history of repair the battery was replace and i think the cause is the battery need help
Cholo Cabontocan tarafından
2015 is an error regarding the insufficient charge of your battery to even enter the iOS to charge. Get a new battery.
Ravi tarafından
@me_ravi I have got a new battery and also charged it over night. Yet getting same error 2015. What to do?
Dr R Venugopalan Venugopalan tarafından
So, are you sure that the replaced battery is charged? Just by plugging the iphone with a cable is not called as charging. The itunes logo is not a indication of charging. If you know that it is charged, then it would be a NAND Gate problem. An expert in repairing will so the job. It requires micro level work.
You can know that iPhone is charging under 2 situations.
1. When powered off you will get a battery symbol with or without plug.
2. When powered on you know that. itunes symbol on screen is not charging.
Ravi tarafından
