Ana içeriğe geç
The OontZ Angle 3 is a high quality, lightweight speaker made by Cambridge SoundWorks.
Fuzzy static sound when connected to computer using AUX cable
Hi,
When I connect my brand new Angle 3 Ultra to my computer, I get a static sound whenever I play a sound through the speaker. About 3-5 seconds after the sound stopped, the fuzzy static sound also went away.
This continued for every sound played from the speaker while connected to AUX cable, but it is fine when connected with bluetooth. Please help! Thanks.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum
Hi @kylepoh ,
Have you tried a different aux cable?
Do you hear the static sound when you connect a headset to the computer's audio out connection that you connect the aux cable to?
tarafından
Hi @jayeff Thanks for the quick reply. Yes, i've tried changing cables and also changing devices (i tested on both my PC and my iphone). Both devices exhibits the same fuzzy static sound.
tarafından
I just discovered that the static sound on my went away after I disconnected the USB cable I had plugged in. I suspect the problem is that the cable does not have a choke on it to block stray RF from getting into the end device.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @kylepoh,
As it is “brand new”, and that you’ve tried different audio sources and cables, I suggest that you follow the directions in the manufacturer’s warranty statement and make a claim for a warranty repair or replacement.
You may have to be quick as it appears that they only offer a 90 day warranty.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Kyle Poh sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 19
Her zaman: 5,304
