high pitch sound when play button is pressed
when play button is pressed down there is a high pitch sound, when the volume button is turned low it disappears and then when on high it is a high pitching noise.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
This is a common problem that is usually resolved by cleaning an internal multi-bank switch. The problem is a feedback loop that is caused by dirt/debris inside the switch which connects a couple of circuits that should be separated. Open up the unit and spray all switches with a lubricating electronics switch cleaner. Engage the switches multiple times and the problem should be resolved.
Dan
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 48
Her zaman: 2,339
